Old 01-27-2012, 02:30 AM   #17
Dave928
Location: Seattle - It's not Hell, but you can see it from here!
just got mine back from the shop for the LN retrofit today - 2001 S, 85k miles.
IMS bearing (original double roller was fine, drive car moderately aggressive)
clutch, press plate, flywheel (the rubber buffer was failing)
RMS
AOS
oil change
($3,150)
water pump (was leaking from impeller shaft)
serp belt, tensioner and rollers
coolant tank and cap
brake flush
fuel filter
spark plug tubes/seals
987 motor mount (rubber was split about 3/4 way thru)
exhaust repair
check cam deviation (well within spec)
$6,700 total
also had the windshield replaced while at the shop (w/factory glass)
Chris's German Auto, Bellevue WA :dance:
dave
2001 Porsche Boxster S
1988 Porsche 928 S4
Dave928 is offline   Reply With Quote
