Old 01-26-2012, 04:40 PM   #1
JFP in PA
Originally Posted by LAP1DOUG View Post
Actually there are two vesrions of the electric valve system. One is a standard solenoid that Canton warns is for start-up pre-oiling only. I don't know why, but I had guessed it must be a reduced port size valve.
The other electric valve option is supposed to charge the accusump slowly, but flow out at a higher rate. I can't imagine how / why this works.
I think you may be misinterpreting their information; the EPC series only releases oil at the preset pressure ranges, it does not restrict the amount of oil released, only the pressure at which it is released.
