Old 01-11-2012, 10:36 AM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by WhipE350 View Post
+1
Also check the rim, these guys bend easier then you would expect. Of course when you get the new tire they will tell you while balancing it if it is bent. The inside of rims bend when hitting things and you don't feel it until driving around 70. It happened to me on my previous Benz and I had it fixed by a mobile rim straightening company.
Make sure they first "balance" the bare wheel to see how imperfect it is. If it calls for more than 1.5oz to balance you will need to use the following procedure to minimize vibration: The cause of vibration is that the tire and the wheel assembly isn't exactly round. When the high spots on the tire and the wheel match to each other, it doubles the amount of runout , or "hop." If there is a hop the vibration will not end when you rebalance your tires. A hop can often be fixed by simply loosening the tire on the wheel and turning it 180 degrees, reinflating the tire after relubricating the bead. If the problem persists, rotate the tire another 90 degrees, and again 180 degrees if there is still vibration. Doing this allows for the high spot to be tried at each quarter of the wheel, and at one of the points, the tire should be round. From here, rebalance the tire and test drive to check for remaining vibration. If you still feel it, the problem is either in the tire itself of elsewhere in the vehicle.
