Old 01-06-2012, 12:28 PM   #3
Brad Roberts
Brad Roberts's Avatar
We use a small pry bar. You need to load and unload the ball joint to see if it has any play in!
Want to be cheap? Use a basketball needle and push grease into the rubber bushings.. see if the noise goes away
I stopped beating people back in 88 (age 18) when I realized I could not afford the lawyers
B
Brad Roberts is offline   Reply With Quote
