Old 12-03-2011, 05:42 PM   #1
pothole
Fault lights and buckets / non-airbag wheels
Is it possible to fit aftermarket bucket seats and / or a non-airbag steering wheel without triggering the airbag fault light in an early 986?
Here in the UK the MOT road worthiness test is changing soon. The new version will stipulate a fail for error lights indicating faults with airbags, ABS, stability control, you name it. If your car has any of these things, the fault light must not show.
In theory, you cannot just remove the bulb as they will check the bulb is working by turning the key to position one or whatever.
I'm hoping to fit buckets and possibly a different wheel. Thanks in advance.
pothole is offline   Reply With Quote
