Old 10-23-2011, 05:01 PM   #1
Johnny Danger
Johnny Danger's Avatar
Originally Posted by ChairmanRon View Post
I plan to do the OBC hack on my '03 986. Since doing the job requires disconnecting the battery, I figure I'll do a battery replacement concurrently.
Question: What do I need to look out for before/after doing a battery disconnect?
The manual makes all kinds of references to window positions, memory, etc. Is this real or just takes care of itself?
Radio: My '03 was purchased used, and I see no radio card anywhere. The manual, and the radio manual, make no reference to a radio card or code. Maybe the radio in '03 doesn't have a code? The manual only refers to a transponder in the radio that is matched to the car.
Anything else I should know before/after?
Cheers,
Ron
Disconnecting the battery will require re-coding the radio. If you don't no the code (because you don't have the card) you'll be SOL !
