Old 10-06-2011, 07:28 PM   #2
dghii
The level works. Don't make this difficult!
Honestly...use the level to get the two arms in the same position (or very close) and then connect the clamshell, lower the thing and check your alignment. You'll see once you start this that it is not magic. Just play with it a bit and you'll see.
I've done two boxsters this way and have not spent more than 15 minutes getting things lined up after starting with the level.
