Old 07-22-2011, 09:48 AM   #10
JFP in PA
Originally Posted by Allen K. Littlefield
JFP, would the deeper sump with the baffles add enough extra oil to be of any cooling assistance? Will the larger oil cooler fit without modifications in a base 2.7 model?
AKL
Problem with most sump extension kits is that they only add about ½ quart in capacity, and lowering the sump cover any further is asking for trouble. Such a small increase in total oil capacity (about 5%) is not going to do much.
The “S” cooler is a drop in, bolt up swap for the base unit. Be sure to replace the four o-rings or you will have leaks, and make sure the small hose on top is connected; as the oil cooler is the highest point in the cooling system, it is where air will collect. The line on top of the unit connects to the surge tank in the rear boot to help get any entrained air out of the system.
