Old 07-18-2011, 02:41 PM   #4
Burg Boxster
Suggest using blue painter tape to mark location for setting. However, if you're still afraid of screwing up their alignment, you can put down some soapy water on the surface so you can slide the stickers around a bit to line them up properly. Just make sure you squeegee out any soap/water to get full adhesion. Painters tape should be more than sufficient though...
Good luck
