Old 07-12-2011, 03:38 PM   #1
JFP in PA
If all your coolant looks like that, you are going to need more than a simple "drain and refill". That looks more like an intermix issue (coolant/oil), which would mean that somewhere in the system, oil is getting into the coolant. That would need to be located and corrected, then the system would need to be cleaned out throughly with a cooling system cleaner like Prestone, until only clear water came out of the system. Then, and only then, could you refill the system......
