Old 06-26-2011, 09:12 AM   #12
JFP in PA
Originally Posted by darkstormvx
I think if the battery needed an initial charge the manufacturer would've indicated it. In any case, the very next day after install I made a 450 mile trip to DC and back. Wouldnt that be sufficient to charge it?
Yes, it should. The issue is not the level of charge, it is the power reserve capacity (amps) of the unit; the Braille is light because it does not have the lead/lead oxide mass necessary to store the power to run all the stuff in the car, like your aftermarket stereo system, which is a huge power draw. These batteries are problematic for street use.
You need a correctly sized battery...............
