Old 05-16-2011, 10:00 AM   #16
johnsweden
this just happned to me last night - my rear drains were clogged and i was carrying around a bathtub full of water - thankfully none of it got into the car at all.
here is a picture of the driver's side rear drain tube - it is the the actual HOLE at the end of the deep section of the plastic under neath the convertible top. it is located at the same spont on teh passenger side.
in order to see and get access to this drain, you need to start opening your convertible top, once the top has gone about 10 inches away from the windshield - stop moving it - this is called the "service position". now, with the top in this positon, you can see and get to these drains.
johnsweden is offline   Reply With Quote
