I posed the same question in another thread. 265/40-18 tires and 265/35-19 tires have the exact same 26.3" diameter, so it's not a problem for ABS or PSM. The 19's are a factory size, with the same section width, so they shouldn't change the handling balance, except to "respond" quicker due to less sidewall flex. The reason I was considering it was concerns over wheel/tire damage with the very short sidewall of 19" fronts. The Corvette and Lotus, and I'm sure others, have staggered wheel diameters. As far as appearance, I would also like to see some pictures.
