Old 03-07-2011, 10:59 AM   #1
JFP in PA
Originally Posted by jamescw8
Hello, I have developed an oil leak directly from a large hexagon shaped bolt on the right rear of the engine block (images attached below).
The leak isn't where you would expect if the RMS or IMS was leaking because it is in front of the clutch housing and just behind the sump pan. The clutch was replaced a year ago.
Does anyone recognise this part of the engine and if so does the bolt just need tightening or am I looking at worse issues.
Help much appreciated!
The oil pump on an M96 is next to the water pump on the front of the engine, and shares the same metal gasket with the water pump. That looks more like the main intermediate shaft tensioner, which fits inside the crankcase near the flywheel.
