Old 02-01-2011, 10:03 AM   #11
thstone
With 32K miles on the clock (and assuming that the 30K service was done), all you'll really be looking at (from a mandatory viewpoint) are oil changes until 60K miles.
If you want to do some preventative maintenance (because its a 10 yr old car), then you can probably spend around $1-2K more if you do the work yourself or double that to have it done.
Otherwise, its just the usual wearables like tires, brakes, and clutch. Tires can need replacement based on age rather than just wear. Brakes and clutch are mostly based on how it was driven before you purchased it.
Dealer PPI will give you a good evaluation of all of the systems so you have an idea of what needs to be done right away and what can wait.
