Old 12-22-2010, 11:50 AM   #12
JFP in PA
Originally Posted by kcpaz
Maybe I'm ignorant (which is very possible since I've never personally rebuilt a Porsche engine) but why do you feel that an intermediate shaft is so necessary? At the risk of comparing apples and oranges, Subaru doesn't use an intermediate shaft (on their 4 cylinders, or their 6 cylinders) and IMO, they are better off for it. Why add another system to fail?. Reminds me of the Mitsubishi 4G63 motors with their balance shafts. "Enthusiasts" remove the shafts all together because they aren't necessary and its just one more system that can cause timing belt issues.
Not quite the same thing.
What you are referring to is removal of the balance shaft, not an intermediate shaft. The makes you point out use a rotating mass to dampen vibrations. The IMS in a M96 Porsche is not there for this purpose, the crank turns one end of the IMS, the other end turns the camshafts; remove it and the engine will not operate..................
