Thread: O2 sensor check
Old 09-28-2010, 06:57 AM   #2
extanker
check your throttle body and idle air controll valve for coking [crud]. if it failed a smog test i would think it will force a CEL . an exhaust leak can fool the 02 sensors making them think the car is lean so they richen the mix. look at injector on time [mil/sec] ....you will need normal specs to compare
extanker is offline   Reply With Quote
