Old 07-12-2010, 06:58 AM   #6
Allen K. Littlefield
Allen K. Littlefield's Avatar
If you can loosen the badge at all you could use a butter knife to pry up on the badge itself as you 'unscrew' the nut. You may have to recruit the spouse or someone else to help you with this if you have trouble doing both unscrewing and prying up on the badge at the same time as it is a bit awkward.
AKL
