Old 05-15-2010, 12:58 PM   #1
Aron in Toronto
You should be able to reset your air bag light with your Durametric assuming there is no pending fault. The typical fault is a bad ground in one of the seat belt receptacles.
The oil level check countdown clock on the 986 is a timer that signals a short waiting period before the electronic oil level gauge will give a reading. I think it’s approximately 5 seconds on a cold engine and about 5 minutes for an engine that has just been shut down.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
