well since the OP has no cats already since there are only two in the midpipes and he has removed them it is definitely in the muffler. change the muffler... change the sound. I recommend looking at spec boxster setups online because most if not all have testpipes in them (no cats) and some form of muffler. the video sounds great however, you need to buy the midpipes from them to use their muffler.
hi flow cats in my mind are a waste of time and money. so very pricey and you dont lose much weight (if any) and you gain minimal power (if any) at least with a cat bypass you may not gain or lose any power but at least you lose weight. and with this spec boxster system or with an aftermarket muffler that is even MORE weight lost and a better sound.
