Old 05-01-2010, 12:42 PM   #2
Christian H
Christian H's Avatar
Originally Posted by jaykay
....yes has anybody had this "vent box" out mine wont budge and would hate to break something or start prying on leather
I took these pictures when I was painting parts of my interior, if you look carefully you will see the hole for the third screw,
As you thought it is behind the light switch (pull the switch out and press the tab underneath with a slim screwdriver it should pull straight off) then remove the light switch nut, the third screw is angled towards the centre of the dash.
The vent takes a bit of "tugging" but should come out, once out all the parts are numbered,hopefully you will be able to click the vertical actuator back in place.
PM me if you have any problems.
Christian H is offline   Reply With Quote
