Thread: Transmission
Old 04-29-2010, 12:25 PM   #7
JFP in PA
OK, tiptronic service 101: There are two plugs on the bottom of the trans, one is a drain plug, the other is a fill opening that has a riser tube that extends upward. To refill the Tip, remove the fill plug, insert the special upside down "J" tube fill hose so that the bend of the J is over the top of the riser tube, pump in the ATF until the excess starts to seep down the riser tube. Reinstall and torque the plug; Miller time....................
JFP in PA is offline   Reply With Quote
