Thread: Top Replacement
Old 04-28-2010, 07:18 PM   #6
schoir
Originally Posted by manxman
As anyone replaced their top by themselves? Thinking of replacing my 97 Boxster's top.
I installed mine by myself a couple of years ago, using and adding to the write up that was originally started by Fred Adler, and I have repaired a few tops for friends. It's definitely doable if you have some mechanical ability, a lot of patience, and don't cut any corners.
Get all of the parts you need to complete the installation beforehand so that you don't end up having to stop and wait for parts. Since yours is a '97, the "mushrooms" on the clamping rails will be difficult to remove without breaking them, but not impossible. You should also line up some double sided tape and some material to make up your own foam seals.
It will all make sense once you read the DIY and then dive in. Be prepared for a fairly long day, so pick a nice day so that you can enjoy the work. It's very rewarding once you step back and take a look at your handiwork for the first time.
Take a few before and after pics and post them here. We like pictures!
Regards, Maurice.
schoir is offline   Reply With Quote
