If you remove the oddments tray/ashtray from the console, you will see the switch back in there. Try jiggling the wires going to the switch - sometimes it works. If not, then a new switch is under $5 from Pelican and your Bentley should tell you how to remove the console if you need help with that.
Also, do a search in this forum - the topic has been addressed a few times and you should be able to find some good info.
