				Update
			Although I believe that I connected all hoses correctly, that is my starting point when I get home tonight.  As mentioned I did drive it for about 8 miles after I put everything back together.  Ran fine, actually replaced the AOS just for fun.  Although I have owned the car for only 3k, I thought with 67k on it, I would follow the ounce of prevention lbs of cure route.  Now with the "no good deed goes unpunished" reprisal....it stings....
Is the trip on a vacum system or electrical system?
Ok, getting stranger....Last night I started engine....Idle perfect, no smoke,etc.  Put car in Reverse and it shows 5th gear, no movement.  I put car in Drive and goes to 5th gear (will crawl) but after I let the car warm up to around 180 degrees. I was able to put car in drive and with the paddle shifters click down through the gears (but only in Drive) The paddles responded slow but I was able to run the chain 5-4-3-2.  Put car in Reverse and cannot paddle through the gears, stays in 5th gear, and will not move.
I did wash the engine after I installed the AOS.s   Does anyone know if the shifting is controlled electronically or by vacuum?
				Boxzilla
2001 Black "S"
De-badged
DRL hack
						Reason: updating information
