Old 04-08-2010, 08:30 PM   #5
JamesBorisPerez
Boxster Radiator Leak
Thank you, there was quite a lot of fluid dripping out, I would say about two quarts, there was no fluid or smell in the truck. I started to try to figure out how to look at the reservoir but it was too hard without a book. I will try to fill up the fluid and check for leaks, if none I will go with your advise. Should I go with the Porsche Radiator Fluid or would a good quality fluid suffice?
JamesBorisPerez is offline   Reply With Quote
