Old 04-03-2010, 08:07 AM   #1
Fletch986
Originally Posted by jonnycool
if your trying to open the front hood you have to take the driverside front wheel off (if you have a LHD car) and take the inner wing plastic lining out, or try to at least loosen it at the front, when you can see under the inner wing liner you have to find a silver metal wire pull, pull this and it will pop the hood and your away!!
Happened to me earlier this year. Get a quality trickle charger that goes on the battery, they save alot of hassle.
This job should take you 1/2 hour approx, there are a few screws under the front bumper too if i remember rightly
I locked my keys in the front trunk (don't ask me how) and i accessed the cable to the front trunk via the drivers side wheel well without taking the wheel off. you have to get under the wheel liner and search for the cable. If i remember correctly you will find an indention in the wheel well liner (at about 2:00 if you think of the wheel as a clock), and the cable is located there. i did it in a parking lot, it's not difficult. Good luck.
Fletch986 is offline   Reply With Quote
