Old 04-03-2010, 07:17 AM   #6
eightsandaces
Found it!
from another BB:
Now you wont believe this!!, without doubt this is the Air/Oil separator, told you you wouldnt believe it.
This is the valve inside the AOS and only emits the noise when on overrun in the early stages of failure, open the throttle and it goes away, at idle it sounds like the idler bearing squeeking.
This is exactly what the bastid is doing...
eightsandaces is offline   Reply With Quote
