Old 03-19-2010, 11:35 AM   #3
tonycarreon
tonycarreon's Avatar
oil change, check coolant and brake fluids. check battery level and top off if needed. ensure you have the toolkit and that your spare is in good condition. if the serpentine belt hasn't been changed, or you do not know if it has, consider having it done before heading out. you can do it yourself if you want - quite easy and plenty of guides online.
if you're going to drive with the top down for extended periods, make sure you have a hat and sunscreen. sunglasses too.
be ready to do a good wash when you get home.
