Old 03-11-2010, 03:53 PM   #7
JFP in PA
Originally Posted by Boxtaboy
Yep, well this seller on fleabay is based out of CT, and a friend was going to drive up to test to see if it would work first before buying. Interesting what you said about the system needing to communicate with the mother computer to gain access to certain updates though. Very sharp of them.
That was apparently one of the objectives for the transition from PST II, a stand alone system that could be cloned or used after being stolen. With a network based system, they know who is using it, there is no need to issue updates, every time a car links up to it the "mother" system can see if things like the DME software have been altered and kill your warranty literally “at the source” so you can't seek relief at a more friendly dealer (every time the system connected to your car, it would say “no warranty”), and they can cut you off from using the network if they don't like you. Solves a lot of problems from their view point..............
