Old 01-25-2010, 01:18 PM   #11
JFP in PA
Originally Posted by stephen wilson
But there is a bit of paranoia, if I don't flush my system every 2 years the brake system will explode and fall out of the car.
Not paranoia, just recognition that the braking performance will deteriorate, and that ultimately the ABS or PSM systems may not function as designed when you needed them most, and that eventually you will be in for some costly repairs that could have been avoided....
If you are not into doing the scheduled maintenance (routinely flushing the system is common practice in many OEM maintenance schedules these days), that’s fine, it is your car after all. But at least test the brake fluid once a year; you just might be surprised at what you find………….
