Old 11-03-2009, 02:22 PM   #1
JFP in PA
Originally Posted by jaykay
I changed my plugs today and noticed the spark plug tubes were all moist around the periphery. There was no leak but they were damp with oil residue.
Change them all or just observe and monitor and only change if it worsens..? I didnt have the tubes on hand for the change obviously
If the tubes are not cracked, all you need is the orings that go on both ends and you are in business, couple of bucks at the most................ You may want to visit a boat yard and find one of these for about $5:
They are called "one inch (2.54 cm) transom drain plugs". Put in a stuck spark plug tube, tighten the wing nut, give it a tug and the most stubborn plug tube pops right out.........
