Old 10-23-2009, 01:24 PM   #3
JFP in PA
Originally Posted by kls
My theory right now is to get the adapter and magnetic drain plug, and the 160 degree thermostat. Sounds like it's fairly easy to install everything, and maybe I'll be able to squeeze a few more miles out of the 2.7.
As you have a 2.7, you should also consider going to the "S" oil cooler if you have not done so already. At more than twice the size of the base heat exhanger, it is a great upgrade for $200.................
