Old 09-22-2009, 06:00 AM   #1
cnavarro
Originally Posted by Flavor 987S
Here is an interesting oil write-up. I have zero opinion on the findings or validity:
http://www.animegame.com/cars/Oil%20Tests.pdf
The Timken Falex bearing test has largely been discredited as a valid method of testing oils - the Holden/Commodore magazine that published that article later published a retraction.
What the test shows is how much moly is in the oil - oils with a poor score have little or no moly - oils with alot (Royal Purple, Redline) have the best, etc.
The test can also be skewed depending on how you perform the test. Knowing how moly interacts with pressure and wear surfaces, it takes anywhere from say 30 seconds to five minutes for moly to form a new wear surface consisting of "glassy plates" when then are sacrificial. Depending on the pressure exerted on the torque arm and how fast the load is applied, this will affect the amount of moly wear film and it's load bearing capacity.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
cnavarro is offline   Reply With Quote
