Old 08-31-2009, 09:44 AM   #1
silbord
The very first thing you should be doing is get the car to someone with an OBD II scanner capable of real time data capture (PID); have them check what your water temp really is at before you puke something major.
You could have a bad dash gauge, temp sending sensor, water pump, externally blocked radiators, or dead thermostat; you need to start eliminating items one at a time rather than just swapping out parts……………
JFP - Thanks for your suggestions. I reviewed the previous owner 's service records and found both the water pump & thermostat was replaced last year. I would think that they should not go bad already.
Where can I buy the OBD II scanner w/ PID?
silbord is offline   Reply With Quote
