Old 08-19-2009, 07:02 PM   #4
986Shaft
The hesitation we had seemed to mainly occur in 2nd gear, and I took it to be a fuel injector problem. I posted the information because it was the only mechanical issue we noticed prior to IMS failure.
Jake sounds certain that a failing bearing wouldn't cause such a hesitation, so I guess it's not an indicator for the IMS bearing.
986Shaft is offline   Reply With Quote
