Thread: understeer
Old 06-17-2009, 01:07 PM   #2
Brad Roberts
Brad Roberts's Avatar
Lots of information.. but I promise tire pressure will not correct this problem. I use these terms to help people out:
1. Course adjustment (adjusting the anti roll bars if adjustable, changing the camber or toe)
2. Fine adjustment (tire pressures and shock settings)
You need a course adjustment, and since you don't have an adjustable bar there are really only TWO things you can do.
Put the rear tires on the front (increases grip with larger tire contact patch and decrease rear grip with smaller contact patch)
Or disconnect the front anti roll bar
You need a course adjustment to "discover" your car. These recommendations by others are all "true" but you will drive yourself nuts trying everything you read here. Disconnect the front bar or swap the tires. Then prepare yourself for the change
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
