Old 06-09-2009, 11:42 AM   #1
Brad Roberts
Brad Roberts's Avatar
They are NOT like the Tarret's.. and you will soon find out the difference. TRG tried to sell drop links with the same size heim you see in the pics above.. and it doesn't work. Your heims will break. It is just a matter of time. In the front of our cars (and 996's) you have to have X amount of movement in the heim. The heim's you have do not have enough for full lock to lock steering with a shock in full bump. It will snap off at the threads leading into the alum.
It requires a larger heim.. and.. you will learn that there is a HUGE difference in heim manufacturing. The cheap ones rattle and make noise after 100 miles. The expensive ones will never make noise.
Not sure where you got your Tarett pricing.. but.. Rears = $200 Fronts = $275 and with minor effort, he gives out *some* discounts.
Do not cheap out on your suspension. It ranks second behind safety equipment. Break a heim going into turn 9 at Willow Springs and you will be going off at 125mph across the dirt heading for the green monster. BTDT.
B
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
