Old 05-31-2009, 06:52 AM   #1
Allen K. Littlefield
Allen K. Littlefield's Avatar
Litronics
Those are the more expensive Litronic headlights. The amber you see comes from a clear amber plastic shield in front of the clear bulb. This can be removed and a silver bulb that blinks amber can be installed. Tricky process to remove amber shield with use of a soldering iron and 'skill'. This will completely remove all amber from front end but will make the lights no longer stock and less desirable if you want to sell them in the future unless you can find another enthusiast. You realize you must now buy the clear triangular corners to complete the look, around $33 I believe or possibly less if you keep up with the sale stuff. Also those Litronic lights have an extra leveling device that you can or cannot install depending on your needs. There are others on this list with a lot more knowledge and answers that I can provide and I am sure they will be getting back to you soon.
AKL
