Old 05-30-2009, 08:49 AM   #10
shaman1204
[QUOTE=Brad Roberts]Rear shock mounts are blown out. Did *somebody* happen to install new shocks not too long ago? I'm not familiar with your car.
To check the engine mount..place a long prybar between the body mount and the engine mount. Lift or pull down depending on how you place the prybar. 99% of every street car I look at it BROKEN. Porsche knew there was a problem with them and changed the design for the later Boxsters and Caymans.
No one installed new shocks that I know of, they look original. I will have to check the motor mount as you suggested. Thanks for the input.
shaman1204 is offline   Reply With Quote
