Originally Posted by shaman1204
OK, so I had the dreaded rear suspension clunk, worse on the passenger side than driver's side. Last December I had both rear lower control arms replaced by te dealership. Slight improvement, but the clunk was still there going over rough pavement and sharp bumps.
A couple weekends ago I replaced the rear track arms with debluzparts (sp?) adjustable rear track arms. Clunk is now almost nonexistent on the driver's side, but the passenger side now has more of a metal on metal sound when driving over rough pavement and sharp bumps. It even makes a slight sound when braking hard and coming to a stop, as if something is sliding back and forth. I've checked and everything is bolted tight.
Any suggestions on where to look next? This issue is driving me NUTS!
Make sure the nuts are tight on both ends of the drop links to the sway bar.
