Old 02-18-2009, 12:51 PM   #1
insite
Originally Posted by yellowboxster01
I think I found the answer to my question. There's 3 mounting spots on the header to midpipes. Two of them have nuts you access from the backside and the top one, the nut is welded to the header and you access the bolt head from the other side. Thus, making whatever is in the way...not in the way.
Now, I'll have to go see if this is the case.
this absolutely IS the case; you're talking about the header flange on the passenger side. indeed the top nut is captive; remove the bolt from the other side.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
