Old 11-30-2008, 09:51 AM   #1
JFP in PA
Originally Posted by radiodjkev
I have tried test's with a cheap Sears mulitimeter..
(so it says, but I think it is far short of a multimeter) and I have tried all the settings. The meter has on it: dcv, acv, dcma, dcua, temp, and there are 5 different dials to read from..
I just can't get anywhere with this problem. I have to disconnect my battery anytime I leave the car sit for more than 3 hours. It is a strong drain.
And it will also drain like this with all fuses removed from fuse box.
No lights on, no Ignition drain, key out always. No aftermarket completely stock.
Kevin
What you need to do is disconnect the + cable at the battery, set your multi meter to "milli amps" (mA) and connect it between the + cable and the battery. It will then read the current draw on the battery. You can then pull fuses and relays out, one at a time while watching the meter for a drop in the current draw. Replace each fuse/relay after each test, and by a process of elimination, you will eventually indentfy the circuit or circuits that are causing your problem............................
