Old 11-05-2008, 10:00 AM   #17
JJJ
hi,
i have those circle water spots on my top and it's hard to get off...
i use the Raggtopp cleaner...
am i supposed to spray the area, and let it soak for the 10-20minutes recommended then use a brush and try to scrub it out??
i've tried spraying the raggtop and applying some water and using a brush to rub it out and it's having a hard time rubbing out...
For those who have been successful getting rid of those spots, what procedure did you use? Or should I just try the 303 cleaner....
Thanks.
JJJ is offline   Reply With Quote
