Old 09-01-2008, 11:27 AM   #11
Brad Roberts
Brad Roberts's Avatar
Now its time to visualize Take a look at the length and positioning of the stock bolts. I try to do as much as I can up on top prior to jacking the car up and getting underneath. I can easily remove the two M6 bolts (10mm head) from up top utilizing a short 10mm socket on a 1/4 inch drive ratchet and a Zippy 10mm wrench.
You will be removing these two small bolts. They thread into the block. Once you get them broke loose, use JUST the socket to unscrew them. They will come out pretty easy.
Use the 1/4 drive with 10mm socket on the top one, and the 10mm Zippy wrench on the bottom one. YOU CAN DO THIS from the top of the car. Just feel down the side of the AOS. I do my damnedest to stay out from under the car until I have too. I shot these pics from under the car, just to show everyone where the bolts where located.
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
