Old 08-24-2008, 08:08 AM   #4
Brucelee
Brucelee's Avatar
Originally Posted by donjuan143
OK the problem all started when i got the check engine light on. then whenever i used to fill my car with fuel i couldn't start up the car easily. then the problem reached to a new level. that's whenever i turned on the A/C the car used to get switch off by it self while I'm driving it. (bearing in mind that i took my car to the dealer for all the issues and they changed the air mass flow and still didn't resolve the issue nor they can find the fault).
so now after i took the car from the dealer (assuming they fixed it by changing one part) i noticed that the car vibrates while i turn on the A/C.
so the mechanic at the dealers told me that there might be something wrong with the engine that its not able to take the load of the A/C (does it makes sense?)
Sounds like your mechanics are not that skilled. To me, this much more sounds like an A/C issue, not an egnine issue. Apparently, the A/C unit (compressor) is creating a larger draw on the eingine that the system is engineered for.
Is this a Porsche dealership you are dealing with?
Rich Belloff
