Originally Posted by Lordblood
The liquid is right under the engine on the right side, right under where you put in the oil and coolant.
I just started the car up and let it run a little bit, engine heat is still normal. I'm hoping it was just a little overflow, as I did just put in coolant.
Overflow or cracked coolant tank, which is very common in the Box.
Either way, you should be fine till Monday.
