that is for adjusting your camber. even if you'd marked the old position, every time you disconnect your lower control arms in back, you should have an alignment done.
rear camber and rear toe are related, so if this setting is off, BOTH camber and toe will be affected. go get your alignment set and you'll be good to go. what springs did you install?
