Old 07-07-2008, 05:11 PM   #14
Quickurt
Quickurt's Avatar
Originally Posted by blue2000s
Motec is a complete, self contained engine management system. It uses the engine's existing sensors, or sometimes additional ones, to determine fuel and spark timing. There are several systems on the market that do this, I've had a Haltech (another manufacturer) running my rotary engine for a few years that I tuned. It's a big job and it takes a long time to get it right.
These systems allow complete control over the mixture and spark timing of the engine, you don't have to go through the stock ECU at all. The stock ECU is typically completely removed from the car, or at least severely crippled so that it doesn't actually control the engine itself.
It doesn't use a MAF to sense load, so no more fouling, but every time you make a change to the engine, including intake and exhaust, you have to re-tune because it's MAP based.
We used a Haltech when we put a Honda engine in a Formula Atlantic Swift DB4(first one done). I thought CAD designing and CNC machining all the adapters and mounts was a big job until it came to just helping my engine builder with the map, since no-one had done a 1.6 Honda engine with the Fuel Injection system we had picked.
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
