Old 05-05-2008, 07:43 PM   #1
Brucelee
Brucelee's Avatar
Pilot Exalto A/S radials are the entry-level High Performance All-Season members of Michelin's Pilot family of performance tires. Pilot Exalto A/S radials are designed for sports cars, coupes and sedans to blend responsive handling and long wear with year-round traction, even in light snow.On the outside, Pilot Exalto A/S tires feature Michelin's Life Maximized All-Season Adherence Compounding (formulated to balance dry grip, wet traction, light snow traction, and tread wear) molded into a directional tread design to provide handling in nearly every weather condition. Siped independent tread blocks combined with wide circumferential grooves and variable width lateral tread grooves help eject water from under the contact patch to resist hydroplaning and enhance wet traction.
Internally, the Pilot Exalto A/S radial's twin steel belts are reinforced using Michelin's Banded At Zero (BAZ) technology (spiral-wrapped reinforcement) to stabilize the tread area, allowing it to withstand centrifugal forces at high speeds while minimizing tire weight and improving ride uniformity.
Michelin Pilot Exalto A/S tires feature black sidewall styling with black letters reversed out of a circumferential serrated band.
Rich Belloff
